Sir aoud . . . . . . .
The basic number that you are looking for is that very bottom number
For the top numbers, they are suspect to be code date or production runs on the first part and the last two markings numbers are usually relating to pin treatment or casing variants.
In these units that would be the very end BF and AB aspects.
Here are three pics, two of them are your referenced units, while the FIRST unit is a real bona-fide, certified unit offered by Mouser in the UK.
Note the sharp defined lines of laser marking on the part number of the first unit.
The other two units look to be stamped on markings.
The center unit looks to be having the best marking of the right two.
Also note the mold flash extrusion divots similarity on the first two units. The third is entirely different.
I point out the above, because some popular POWER audio transistors and TV horizontal output transistors had a problem of inferior bogus / counterfeit units being out on the "black" market supply chain.
However many of these devices that your unit used (2? ) . . .replace them both (all).
73's de Edd
73's de Edd
