CFF
I am working on my first project using a 4MHz PIC16F84. The whole
purpose of the project is to set portb<0> pin from HIGH to LOW for a
prolong period (as much as 30 minutes) before tuning back to HIGH upon
detection of activity at porta pins.
My idea is to cascade a series of fully loaded counters (I am using 4
8-bit file registers, i.e. count1 to count4, in my experiment) so as
to generate the required lengthy delay. The idea is simple but it
doesn't work out as expected however.
What's strange about the counting process is count3 will only count
from 0xFF to 0xF5 before reseting itself to 0xFF. That is where my
trouble is about. It has been confirmed both on simulator and my
hardware circuit. If I load the counters with smaller initial values,
say 0x0F, the problem disappears. Of course, smaller values doesn't
generate long delay. Can somebody give me some idea about why the PIC
behaves differently from what the programme logic states?
Below is the problematic code that I've been experimenting. Thanks for
any help.
;;;;;;;;;;;;;;;;; PROBLEMATIC PIC CODE ;;;;;;;;;;;;;;;
list p=16F84
radix hex
porta equ 0x05
portb equ 0x06
count1 equ 0x0c
count2 equ 0x0d
count3 equ 0x0e
count4 equ 0x0f
org 0x000 ; processor reset vector
goto start
start movlw 0xff
tris porta ; configure porta as input port
movlw 0x00
tris portb ; configure portb as output port
clrf portb ; set portb LOW
scan btfss porta, 0
call timer
btfss porta, 2
call timer
btfss porta, 3
call timer
goto scan
timer bsf portb, 0 ; set portb<0> HIGH
; initialise count1 to count4
movlw 0xff
movwf count1
movlw 0xff
movwf count2
movlw 0xff
movwf count3
movlw 0xff
movwf count4
delay decfsz count1, f
goto delay
movlw 0xff
movwf count1
decfsz count2, f
goto delay
movlw 0xff
movwf count2
decfsz count3, f ; THIS GUY NEVER COME TO ZERO BUT 0xF5, WHY???
goto delay
movlw 0xff
movwf count3
decfsz count4, f
goto delay
bcf portb, 0 ; set portb<0> LOW
return
end
any help.
list p=16F84
radix hex
porta equ 0x05
portb equ 0x06
count1 equ 0x0c
count2 equ 0x0d
count3 equ 0x0e
count4 equ 0x0f
goto start
start movlw 0xff
movlw 0x00
scan btfss porta, 0
call timer
btfss porta, 2
call timer
btfss porta, 3
call timer
goto scan
movlw 0xff
movwf count1
movlw 0xff
movwf count2
movlw 0xff
movwf count3
movlw 0xff
movwf count4
goto delay
movlw 0xff
movwf count1
decfsz count2, f
goto delay
movlw 0xff
movwf count2
goto delay
movlw 0xff
movwf count3
decfsz count4, f
goto delay
return
end
