D.M. Procida
Hi. I have an iMac G3, with a built in CRT display. Convergence at the
centre is perfect. Horizontal convergence is pretty good right across
the screen. Vertical convergence is terrible.
The problem is that at the top of the screen, the red beam lands higher
than the others, and at the bottom, lower. So simply moving the beams
around relative to each other doesn't solve that problem. Is there
likely to be an adjustment for this?
Purity isn't absolutely 100%, but it's certainly good enough - there are
no blotchy or mottled ares on the screen, just a bit of tinge towards
some edges.
Thanks,
Daniele
some edges.
Thanks,
Daniele
