Ross Herbert
I have been restoring an old APO Multimeter No.3 by giving it a good going over
inside and out. It's a nice looking analogue MM which is built like a brick
outhouse and it has been well looked after since it was obtained from the PMG's
Stores branch in 1971 at a charge out cost of $68.50. They certainly weren't
expensive at that price - considering they had a 10A ac range using a current
transformer and were made in Australia by Master Instruments. The leather case
was like new into the bargain.
As some of you may be aware, this meter - like the AVO 8 etc, uses a 15V battery
which is no longer manufactured by the usual battery manufacturers. I found that
WES Components sell a lookalike which is supposedly an alkaline equivalent of
the old carbon-zinc pile made by Eveready as the 411 battery. These are labelled
as Made in Singapore and are fitted in a red plastic case the same dimensions as
the original Eveready - but they are about half the weight of the original. I
think they are distributed in Aust by Master Instruments. They cost about $27 ea
in Perth so they are not cheap to say the least. I ordered 2 and received them
today.
Upon connecting my digital meter to the first battery (with no load) it measured
15V initially and rapidly dropped to a steady 13.5V within 10 seconds. Exactly
the same result with the second battery. I didn't even bother to connect a 15K
load and do a nominal 1mA measurement because the result could not be any better
than with no load. I had already determined that the APO M/M No.3 requires the
battery to measure a minimum of 13V in order to be able to zero the meter on the
Ohms x1000 range with leads shorted, so these EVER411's were no good at all.
I took both batteries back to the supplier in Perth (Westec Electronics - the
rep for WES Components)and demonstrated the problem to the counter jockey using
two different meters. He agreed the voltage measurements did not match the
advertised specs and refunded my money.
The point of this story is to advise anyone who may be considering buying this
battery from WES (or any other supplier), think twice, and then don't do it.
Since I still needed a replacement battery I called in at Malz and bought a
miniature MN27 12V battery and a 2032 3V Lithium cell for a total of $5.20 and I
am currently shoe-horning them into the casing from the original dead Eveready
411.
today.
411.
