Jamie
20kvolts? that's it?WoolyBully said:I worked on the development of an HV oil filtration device. It used our
20 kV supply, and our plate arrangement and our tank chamber and oil
pump. We PULLED the oil through the chamber and filter media as this
reduced the pressure in the chamber and that was enough to keep arcing
events from happening. Operated with the lid off, it would arc
immediately. With the lid on, the pressure would pull down almost
immediately as the oil's viscosity took some work to pull it through the
piping. That reduced chamber pressure kept it from arcing.
Your curve is for pressures well below that.
In normal air, the voltage required to establish an arc rises as
pressure drops. This is NOT data related to a vacuum. It is for reduced
pressure environments.
The curve plot refers to vacuums and very low pressures.
Jamie
