I found a solution to this problem. I even started playing a bit of piano
tonight!
There is a thing called "piano tabs" which is simply a string of characters
you type on the piano like this...
3|--------c---c---c---|-c-----c---c---c---|-c-----c---c---c---|
You just press the piano key "c" for the above. The above is the beginning
of the "Wedding March".
Then there will be several lines if there are multiple keys to press at the
same time like this...
3|--g----g---g---g---g----g----|-
3|--e----------------e----e----|-
3|--c----------------c---------|-
However I've improved on the above system! The existing system uses groups
of 7 keys on the piano and the number 3 above indicates this is the 3rd
group of 7 keys (aka octaves). And that you would press the "c" in that 3rd
group of 7 keys.
Here is a picture of the way to label the keys on the piano using the above
system...
http://tabnabber.com/documents/keyMaps/49keymap.gif
Note that the letters repeat themselves. (c, d, e, f, g, a, b)
So I just labeled each set of letters on my piano keys so each group looks
separate. The first set of letters is smaller and higher up on the keys. The
next set lower. The next set larger letters. The next set higher up, etc.
(Whatever to distinguish the sets.)
So you can clearly see where each group of 7 keys starts and ends.
Then I numbered the sets with numbers above each letter. 1 above each letter
for the first set, 2 above each letter for the second set, etc. (Instead of
writing 1a, 1b, 1c, etc.)
Next I took highlighter pens and colored the piano keys for group 2 yellow
and all the piano keys for group 4 blue.
Then on the "piano tabs" music, I can now highlight the rows of letters to
be played in the 2nd yellow section yellow and the rows of letters to be
played in the 4th blue section blue.
The white 3rd section would be in-between yellow and blue highlighter. And
the white 1st and 5th sections above or below the yellow and blue
highlighter.
So EZ to see which section in which to press the key now!
Here is the "piano tabs" music for the Wedding March"....
http://tabnabber.com/view_Tab.asp?tabID=6668&sArtist=Misc&sName=Wedding+march
Here is the instructions for using the piano tabs notation system
(simple!)...
http://tabnabber.com/documents/howtoreadtabs.asp
Following is all about the regular music notation system which is impossible
to understand. In the very first part of the following, it says "When only
one part (or voice) is written on the staff...".
Well it lost me right there! What is a "staff"? And it goes on to use all
sorts of terms which I don't know the meaning of! (Explain these things
please!)
http://www.gutenberg.org/files/19499/19499-h/19499-h.htm
Then the link below explains the details of what everything with regular
music sheets means, but I would have to spend quite a bit of time
"translating" all these symbols to say the least!
http://en.wikipedia.org/wiki/Modern_musical_symbols
