mikem
ECAD users,
Looking for recommendation for an ECAD system suitable for use by
a small to medium engineering company. We have 5 EEs, and a few techs.
We do relatively small, up to four layer, surface mount, PC boards,
with less than a hundred components. Probably only do a few boards
total per year. Big goal is to have schematics be useful for
documentation and parts lists for purchasing and fabrication.
Parts libraries are a big deal. Ideally, the physical parts/simulation
model libraries should have any part you can buy from DigiKey...
We would like to put schematic capture, Spice-like circuit simulation,
waveform tools in the hands of each engineer, running on PC platforms.
The PC layout, routing, and creation of artwork can be concentrated
onto one trained specialist, and run on just one workstation (ie dont
need each engineer to lay out PC boards).
If would be nice if there was a way to export a 3d physical
representation of a complete PC board to our 3d mechanical design CAD.
Thermal analysis of heat flows might be nice, but not if it breaks the
bank.
So what are other folks with similar requirements using? If you care
to reply via email, substitute the letters ced for CharleyEchoDelta.
Hams and pilots would know to do this...
Mike Mladejovsky
Sarcos
SLC, Ut
bank.
Mike Mladejovsky
Sarcos
SLC, Ut
