Abstract Dissonance
I was thinking if it would be possible to create a completely electronicly
controlled SPDT switch using the following method:
create a conductor that looks like the following
B /
A------<
B \
The electrons enter from A and across the conductor there is an electric
field(maybe something like a capacitor).
Then with the right voltage across B to create the electric field one should
be able to "deflect" the electrons into either path? I'm not sure if this
would work in a conductor though as after the field is gone the electrons
would then take both paths... I suppose the field would have to extend to
the branch. Another problem is that it might require very precise control
of the voltage so no current would leak into the wrong path. One "benefit"
would be that without any applied voltage it would act as a divider.
Just a thought.
AD
B /
A------<
B \
Just a thought.
AD
