V
Vittorio
I've purchased a phone system that's capable of releasing typical
magnetic locks remotely from any extension phone. An accessory called
"external feature module" is responsible for deacivating a mag lock via
a terminal block controlled by any phone. The circut is normally
closed, when opened the power to the mag lock's rendered deactivated.
My mag lock has to be deactivated by closing two leads. For some reason
the manufacturer doesn't want the lock to be unpowered in order to gain
egress. Here's my question. The telephone manufacturer tells me I need
a "normally open" relay that serves a nomally open circut for my type
of mag lock. If I select a 12 VDC (INPUT VOLTAGE) SPDT (CONTACT TYPE)
10 AMPS (LOAD RATING @240 VAC), (POWER COMSUMPTION) 115 mA, 5 PIN RELAY
- spade terminal relay. OR DO I NEED AN ENCLOSED POWER RELAY DPST-NO 25
AMPS 12 VDC 158 mA (STANDARD WITH DC INPUT VOLTAGE) CAN YOU PEOPLE HELP
ME MAKE THIS FLY?
ME MAKE THIS FLY?
