Russell Griffiths said:
"Joe" <
[email protected]> wrote in message
Greetings Joe.
I have that issue, and I know someone who built one.
He is very happy with it.
The unit is powered from the battery under test.
A meter shows the current drain.
A multiturn pot controls the base current to 2 2N3055 transistors.
Each of these has 7 3.3 ohm 5W resistors in par. to ground.
Bye.
Russell Griffiths
Very good Russell, that sounds very much like one at we have work that
someone made up years ago.
It has 7 x 3.ohm resistors in the emitters to ground, and the bases of the
transistors are connected to the centre of a resistive voltage divider
across the battery under test. The divider consists of a 10k multi-turn pot
and two fixed resistors. A 3 or 5 amp ammeter is in series with the
collectors.
Is that similar to your circuit?
Yes it does work well, but it has the disadvantage, that as the voltage on
the battery on test drops, the current also drops, so that at 12 volts with
1 amp drain, the current falls to 600 to 700 milliamps when the voltage
drops to 9 volts.
I need to build some dummy loads for my workplace that are constant current,
regardless of voltage. The circuit in Silicon Chip Sep 2002 does just this
by monitoring the voltage across the load resistors and then controlling the
output transistor (FET). Unfortunately no supplier I could find has this as
a kit, and secondly it needs a separate supply to run it which makes it a
bit messy for a commercial application.
I do have a circuit from the late 1980's that appeared in Electronics Today
which also monitors the voltage drop, so it should work for me as a constant
current load, and it is self powered as well.
Thanks for your help.
