Rein Wiehler
Chuck said:I have a problem with a bunch of Diskless workstation, they are
exploding a filter cap near the CPU. The origional Part is a 1000uf
6.3v. I replaced them with 1000uf 16v. This new capacitor lasted
almost a year. I assume the ESR at the switching frequency is
generating too much heat.
Does anyone have a recomendation for replacing this failing Capacitor?
I am space limited. The origional cap is about 300 mil dia. by 600
mil height.
Should I increase the capacitance?
Should I increase the voltage rating?
Should I parallel multiple capacitors of reduced value? (spreading
the heat load?)
Should I attempt to find a custom capacitor with a lower ESR value?
Chuck Todd
does this happen to be a "ABIT" board. There was problem with low ESR
caps on those boards
rw
