electrical interface problem
Melanie Nasic
Oh, thank you so much.... everything became quite clear as I had a look at
your drawings. I'm not sure if AC coupling like proposed by Jim Thompson in
MelanieCML.pdf is relly necessary. In my oppinion a "plain" resistor network
will do the job, so no need for AC coupling, right?
Regards, Mel
Melanie Nasic
Could someone please do me a favor and post something for me at Newsgroups:
alt.binaries.schematics.electronic.
I think I found a solution myself but I am not sure whether it will work. I
made a drawing and would like to discuss that but I'm not allowed to post at
Newsgroups: alt.binaries.schematics.electronic.
Thanks, Mel
Melanie Nasic
I think I found a solution to the post "electrical interface problem" but I
am not sure whether it will work. I made a drawing and would like to discuss
that but I'm not allowed to post at Newsgroups:
alt.binaries.schematics.electronic. Could someone help me, please?
I'm sorry for bothering you with this question but I'm out of ideas...
Best Regards,
Melanie Nasic
John Popelish
Email them to me, along with the thread title you want them labeled with.
Jim Thompson
Since this is a xilinx related issue you might try to post this
question to comp.arch.fpga where the xilinx folks hang out.
Others have run into this and generally are very happy to give
answers. There are people from xilinx there as well to answer
questions.
[snip]
Also make sure of the rigidity of the 1.15V receiver common-mode spec.
This sounds like LVDS. This number is what the LVDS _transmitter_
puts out. Most of the _receivers_ (Fairchild, for instance, some
parts of which I've designed) can tolerate almost rail-to-rail input
common-mode.
...Jim Thompson
Melanie Nasic
John, would you please be so kind to post my message with the binaries?!
Thanks a lot.
Mel
John Popelish
Thanks a lot.
Your message? Which one?
And I haven't received the binary files from you, yet.
Please email whatever binary files you wish to be posted, to me, along
with whatever text you want included, and I will post the whole thing
on A.B.S.E for you.
Melanie Nasic
Hi John,
I've send them to you yesterday along with my email. I did it again for 3
minutes, could you please check? Maybe your mail program thought of me like
spam?! ;-)
Bye, Mel
John Popelish
Melanie said:
Hi John,
spam?! ;-)
Bye, Mel
Yes, they were in the trash. One of my filters caught them. Sorry.
Posted.
Melanie Nasic
I wonder what is the characteristic impedance of the circuit proposal
CMLmystery.pdf? I think this is the easiest way to do it but I want to be
sure that the CML transmitter still "sees" 50 Ohm line impedance. Any
comments on that?
Bye, Mel.
Jim Thompson
comments on that?
Bye, Mel.
[snip]
qrk/Mark implies that the transmitter can be operated with less output
common mode (as I suspected), so just use my version without caps, use
no divider to set output CM, just twiddle the pull-down R, as in
Mark's version until you get the +1.15V at the receiver. (My values
were line-match based.)
...Jim Thompson
Melanie Nasic
Hi Jim,
don't the changes you suggest effect the line match (twiddling the pull-down
Rs)? Nonetheless I would like to calculate the impedance of Mark's circuit.
Any suggestions how I can find out about the impedance?
Bye Mel
Jim Thompson said:
comments on that?
Bye, Mel.
[snip]
...Jim Thompson
Jim Thompson
Hi Jim,
Bye Mel
[snip]
Oooops! In Mark's version they do affect impedance. Use a single
midpoint pull-down... my divider without the upper resistor.
Insert transmission line into your drawing, then you can visualize
source and termination easier.
...Jim Thompson
Q
qrk
Jim Thompson said:
comments on that?
Bye, Mel.
[snip]
...Jim Thompson
Hi Jim,
Bye Mel
See posting in abse, "electrical interface problem - Melanie_attn.gif"
I'm not quite sure of your electronics knowledge, so I'll show the
steps to finding the equivalent input impedance of the network. This
will work for both mine and Jim's circuits since they are essentially
the same.
Item 1, in Melanie_attn.gif, is the full network. R7 has no effect on
the differential impedance. R7 is only to set the DC bias point for
your receiver. In Jim's schematic (MelanieCML.pdf), the bias parts R8,
R9, C3 have no effect on the differential impedance.
Item 2 shows the network without R7 since the node R7,R4,R5 is at zero
AC potential.
Items 3, 4, and 5 show the step by step simplification of the network
to get the equivalent input impedance of the network. The double bars
(||) mean parallel, i.e. R1||Rb means R1 in parallel with Rb.
Your Rocket IO wants to drive an impedance of 100 Ohms differential,
not 50 Ohms.
The difference between Jim Thompson's circuit and mine:
Jim thinks you need to add termination resistor at the input to the
receiver (the pair of 49.9 Ohm resistors). Jim's circuit gives 17.6 dB
attenuation which might be too much.
I think that the termination resistor is included on the receiver
silicon die. That would be R6 in the schematic. My circuit gives 10.1
dB attenuation. I also use non-standard resistor values only because
I'm too lazy to look up standard values. Boy, it's nice being
unemployed and lazy!
Before this discussion goes on, we really need to know what your
receiver device is. John Larkin brings up some valid points about
simplification of the interface which could null this discussion of
level shifting and attenuator pads.
Melanie Nasic
Hi Mark,
thank you so much for your elaborations. Everything became pretty clear for
me now. So I got approx 100 Ohm for the resistor network now. But as I want
to transmit data in the Gigahertz range aren't I supposed to take a complex
HF impedance value into account? Are there any further calculations I have
to make to gain a conclusion whether this circuit will work for signals with
data rates of 3 Gbps.
Regards, Melanie
qrk said:
Jim Thompson said:
On Fri, 9 Dec 2005 16:27:44 +0100, "Melanie Nasic"
be
comments on that?
Bye, Mel.
[snip]
...Jim Thompson
Hi Jim,
pull-down
circuit.
Bye Mel
the same.
AC potential.
not 50 Ohms.
Q
qrk
qrk said:
Newsbeitrag On Fri, 9 Dec 2005 16:27:44 +0100, "Melanie Nasic"
be
comments on that?
Bye, Mel.
[snip]
...Jim Thompson
Hi Jim,
pull-down
circuit.
Bye Mel
the same.
AC potential.
not 50 Ohms.
Hi Mark,
Regards, Melanie
Yes, you need to consider complex impedances, or more likely how to
minimize the reactive part. You don't say what sort of path your
signal must travel between driver and receiver. If only a couple cm on
the circuit board, this should be manageable with careful layout
practices. If your signal goes through connectors, difficulties can
arise. I suggest getting a copy of Howard Johnson's book, "High-Speed
Digital Design: A Handbook of Black Magic" (ISBN: 0133957241). It has
lots of practical information. Good WC reading. Your uni library may
have a copy. Look for application notes on routing high-speed lines on
printed circuit boards. You usually find these articles for 10 Gb/s
I/O.
If you have access to simulation tools like Mentor's HyperLynx I would
suggest learning how to use these tools. You can simulate your signal
path and see what sort of problems you may run into. Xilinx has Mentor
binary models of the output structure and packaging.
To model the differential impedance of the traces on your circuit
board, you can use ATLC <http://atlc.sourceforge.net/>. It's a
graphically instructive program, well worth looking at the results.
Version 4.4.4 is compiled for Windows. It is a user unfriendly
program, but free and multi-platform.
There are other programs that calculate differential impedance like
Polar's very expensive programs <http://www.polarinstruments.com/>.
Many printed circuit board manufacturing houses use the Polar
programs. You can call your PCB fabricator and ask them for the trace
dimensions. Once you know your PCB stackup, you can talk to your PCB
fabricator. This is normal communication between the designer and
fabricator when dealing with high-speed signals.
