K
Kurt Kaiser
Hi there,
I'm currently having a serious problem: I got an LVPECL clock synthesizer
and I want to connect it to several clock inputs on my FPGA. The FPGA
features 2 LVDS interfaces, whereas each LVDS pair is located at opposite
sides of the device, meaning there will be some extensive routing to do. I
designed a resistor network for the level conversion from LVPECL to LVDS.
What I'd like to know now is
a) Can I route the 2x2 lines (two times differential to the two opposite
sides of the FPGA) one-to-one out of my clock device to the inputs or should
I use a dedicated buffer / repeater IC for clock distribution?
b) If clock buffer are needed, should I use LVPECL buffers and do the
conversion to LVDS level afterwards or should I perfom the conversion before
the buffer and then use an LVDS IC?
c) Where should I place the level conversion network? Is is better to place
it right at the LVPECL output or is it more advisable to do it right before
the FPGA inputs after a transmission line length of about 7 cm?
Any help, comments, advice is highly appreciated!
Thank you all very much.
Kurt
Kurt
