On Thu, 4 Apr 2013 10:53:31 -0700 (PDT), George Herold
Hi guys, A colleague had his flame sensor in his gas furnace fail and
this led to a discussion about how they work. The sensors are just a
metal rod that sit’s in the flame. They apply an AC voltage to the
rod and measure the current going from the rod to the flame nozzle..
The flame is a plasma and conducts ~micro amp currents with ~ 100
volts of drive. Now here’s the weird part. The flame sensor shows
rectification and so only has to sense a DC current. I’m totally
clueless as to how you get rectification. If you scroll down to the
description (back ground of invention) here,
http://www.freepatentsonline.com/5472336.html
you’ll see he talks about different areas being important. But no
other explanation. Anyone have an idea of what’s going on?
If you have a setup like this: (View with a fixed pitch font)
where you have one spherical electrode (large area) and one pointy
one, (small area) then when the pointy end goes negative, the field
strength at the point will be high and it'll be easy for electrons to
jump the gap, as long as it's not too great.
When the spherical electrode goes negative, however, the field
strength will be much lower and it'll be hard for electrons to jump
the gap.
Voila, rectifier!
. +---O <--+
. +--[AC]--+
JF
As far as I know the area thing may be a red herring.
If I believe the patent the prefered electron flow direction is from
the large area towards the probe... go figure.
