Ok so i need to hook up a small electric motor to a speed control so i cab adjust the speed obviously.. The motor will be running around 5v maybe less but i need to be able to measure the amount of electricity the motor is drawing. Any suggestions? The motor will need to turn an axle at a rate of 10-30rpm with or without gears but measuring of the power drawn from the motor is key.
Thanx for any posts
Thanx for any posts
