Hi... New here. I love to turn wrenches. Have done more than a few engine swaps, v8, turbo and diesel conversions. Mechanics are one or my strengths, electronics is a weakness. Hope you guys can help me out with a project.
I have a 26 ft flybridge fishing boat im restoring for the family to use. Im a sailor, i love my sailboats but the family isnt a huge fan and all my sailboats take from one hour to 4 hours to launch and set up to use. This power boat is a floating camper, fishing boat and can pull the family on tubes.
Its currently a v8 chevy 350. A real gas guzzler. Im currently looking for a diesel engine to swap into her to double or triple my gph consumption. The throttle will be a standard spring loaded lever. Pull for rpms. The more you pull the faster the engine goes. Not a lot of force here. It's spring loaded so when you release pressure the spring brings it to idle.
For steering, it currently has power assisted steering. Has a power steering pump close to what you see in a 90s chevy pick up truck. It has a hydralic ram that pushes or pulls depending on which direction you want to go. The steering rack is attached via cable. The cable slides arms forward or back which powers the steering ram.
My boat has 2 steering and throttle stations. It has forward netural and reverse shifting as well.
My 9 yr old is great at video games. Prefers it to most outdoor activity and i hope this helps to change it.
I would like to have push button gear selects. Forward, neutral and drive. Engine needs to be at idle to shift without ripping out gears.
I would like throttle and steering incorporated into a joystick. Forward for rpm, left or right for steering. However in reverse id like to move joystick to reverse for throttle and side to side for direction
I have not done any programming since visual basic back in highschool.
Im hoping you guys could help point me in the right direction for getting this project started. The throttle control should be simple but there is some force on the steering and programming intimidates me.
Thanks ahead guys.
Thanks ahead guys.
