My echo audiofire 12 firewire audio interface has developed a fault and I was hoping someone here would be able to help .
It has the following sypmtoms:
A high pitched whine/buzz when switched on - pretty sure this is coming from the transformer.
Both my desktop and laptop will recognize the device but audio will not play through it. (pro audio apps like cubase dont see it, windows media player won't play - the progress bar doesn't move). The inputs appear to be working fine.
Only 1 of the 2 firewire ports seem to be working at all - windows doesn't see the device if connected to the other port.
Could all this be caused by the transformer? or is that buzzing because of a problem elsewhere?
The psu is UMEC UP0303S-055
Transformer UMEC UP0303S-05 (it also has 0712CG written on it in a smaller font)
I cant find either of these items in the UK. Is there a similar psu or transformer i could try as a replacement?
I do have a multimeter, but no idea how to use it to test the various components.
Any help or advice would be greatly appreciated.
