ECG Circuit
Hi
I have been trying to build this circuit but i have a few problems ...so any help is grateful
I am using battery to power the circuit ...two 9 v batteries in series but connected to ground
I am confused as i dont understand VSS and VDD.....as in what is the difference and how can i appply it..
also when you look at the circuit most of the +- 9V VSS VDD are connected to ground
abit confusing
I am just a hobbyist any help or knowledge would be helpful ....
http://www.cisl.columbia.edu/kinget_group/student_projects/ECG Report/E6001 ECG final report.htm
that is a link to the project i am building ....
I am getting the ECG signal butt when i connect my right leg to ground i lose the signal....
davenn
Hi Kiwan
welcome to electronics Point :)
a bit confusing
with your two 9V batteries connected in series, the VDD goes to the positive terminal of one battery, the VSS goes to the negative terminal of the other battery.
The ground ( 0V) goes to the positive and negative termanials that are connected together
this is called a split supply
attachment.php
cheers
Dave
thank u
thank you
that makes sense
i am now assuming my right leg connects to this ground but i am not getting results i am expecting
not sure what you mean by "right leg" ?
It's the thing that your right knee is in the middle of :D
ECG machines have a number of connections around your chest, and a reference connection as far away from your heart as you can get, That's typically your right ankle.
Yeah, depending on the circuit, the ground connection probably goes there.
with both sides of the optocoupler sharing the same power supply, how the isolation is provided? Is the optocoupler linear?
to davenn
I understand what you are saying but my circuit diagram doesn't make sense to me
im confused so vdd + 9 v will also be connected to the common ground at same time
wen doing pin 4 of the opto coupler???
davenn
to davenn
0V the connection between the 2 batteries is the Ground connection
There are actually only 2 connections to the GND shown and that's in the bandpass filter on the output
The output signal will also be between the output terminal and ground
they really did confuse the issue by showing the same GND symbol for all the power connections as well
that is poor circuit drawing !!
I can understand what they are doing with the symbols there, but for a newcomer its confusing
Dave
hi
"with both sides of the optocoupler sharing the same power supply, how the isolation is provided? Is the optocoupler linear?"
what is wrong with them sharing same power supply .......
the purpose of the optocoupler is to provide isolation for the patient and the instrumental amplifier .......
I am a newbie to electronics so willing to learn by applying knowledge
wat i am trying to do is improve this circuit and add on to it........but i must understand it first and get it to work .........i want to add protection circuits and ADC
eventually make it a 12 lead ecg
The aim of the optocoupler is to isolate the user from the measurement equipment, here the scope.
If you use the same power supply on both isolation sides the isolation is bypassed and the user can be exposed to electrical shocks.
You project is hosted by a college of engineering, assuming we talk about a school assignment all we can do is point you to the right direction . Google a bit with ECG schematic, ECG circuit, ECG isolation and you will find handy information's to go further. By the way better to do it step by step.Starting with the front stage without isolation, then add the inputs protection, then the isolation then think about 12 leads version.
Olivier
Thank you for the help
I am going to take a week and do some research on how i can improve the circuit bit by bit
