We are trying to build an ECG amplifier stage using the INA118P. We have the positive power supply hooked up to 6V and the negative supply hooked up to -6V (battery powered). The reference pin is hooked up to ground. The input pins are attached to insulated wires running to pennies that are used as electrodes. The right leg is attached to ground through a 10k resistor. The output of the amplifier is fed into a NI USB-6009. When we collect data and display it, sometimes we can see heart beats and other times we run rail voltage. When the electrodes are left floating the output runs either +-1V. The gain on the amplifier is set at around 500. We technically have two identical amplifiers to measure the ECG reading at two different points on the left arm. Sometimes we can get one to work and then the other but we haven't been able to get them both to work at the same time. When they are hooked up and not working, one runs rail voltage and the other output runs 0V. We have these components soldered onto a circuit board. If need anymore information please let us know! Any suggestions are appreciated.
Platforms
Content
