finally found the right forum...
OK I cut the board out of the pedal and discovered some real bad looking connections on it, that I will have to remove.
I wrote a schematic for it as it is before I do anything, and I downloaded a couple of free schematics on volume and phase circuits.
Sometimes its better to start from scratch, so I dug around in my shop and found 3 more pots -3pin 200k.
I pulled the 5 way, and made a diagram of the pinouts 1 to 5. there are 10 pins,
Position 1 and 6 have no effect.
Might be a bad switch.
I can't find any volume pots anywhere. Only balance pots, I don't like using balance pots as volume pots, I never can get the response I want, and I always lose some tone or something.
You don't see much highvoltage, loud and clear stage equipment anymore. It's lonely out here.
