DSP analysis of global temperature by Agilent chap
Bill Sloman
Interesting analysis by DSP specialist of global temperature.
http://wattsupwiththat.com/2013/09/...mperature-data-suggests-global-cooling-ahead/
Unlike climatologists this guy knows how to analyse data.
The climatologists do have the advantage of knowing something about the processes generating the data presented.
Atmospheric CO2 levels stuck at about 280ppm from the end of the last ice age to the start of the Industrial Revolution, but they've risen exponentially since then, to the current 400ppm. The halfway point - 340ppm - happenedaround 1980.
This means that half the anthropogenic green-house warming we've seen is concentrated in the last thirty years. It's visible in the curves presented by Anthony Watt, but it's equally clear that the warming we've seen is of the same order as the noise imposed on the global temperature signal by the Atlantic Multidecadal Oscillation (AMO).
The DSP analysis pulls out a 57 year period. The AMO doesn't seem to be a stable oscillation, but its characteristic period - in so far as it can be said to have one - is something of the order of 70 years, which is close enough to 57 years for an analysis of 160 years of data, particularly when thethe last thirty years is bent up by rapid anthropogenic global warming
Watt talks about a 170 year component, but that's just over-fitting the data - he's trying to fit a sine-wave to a hockey-stick. Extrapolating on the basis that a hockey stick is actually part of a sine wave isn't all that clever.
A serious data analyst wouldn't make that kind of mistake - the DSP analysis is clearly tongue in cheek - but Anthony Watt isn't into data analysis, but rather into giving his audience the kind of story that they will be happy to hear.
Raveninghorde
Atmospheric CO2 levels stuck at about 280ppm from the end of the last ice age to the start of the Industrial Revolution, but they've risen exponentially since then, to the current 400ppm. The halfway point - 340ppm - happened around 1980.
The DSP analysis pulls out a 57 year period. The AMO doesn't seem to be a stable oscillation, but its characteristic period - in so far as it can be said to have one - is something of the order of 70 years, which is close enough to 57 years for an analysis of 160 years of data, particularly when the the last thirty years is bent up by rapid anthropogenic global warming
Thanks for your masterly analysis. It's nice to see you haven't lost
any of your religious fervour for CO2 induced warming despite a 17
year pause in warming.
Jeroen Belleman
You mean like it's an opportunity to inject prejudice and obfuscation?
Even if Watt's analysis may have problems, in that it seems to
expose some periodic signals that are suspiciously close to the
length of the sample and its harmonics, the analysis should in
principle be objective, impartial, transparent and public.
The official climatologists' story is none of that. Their
arguments and data are tainted by money and politics. Even
Watt's raw input data can't be trusted because of where it
came from!
Jeroen Belleman
Bill Sloman
I spent too long curve-fitting data to set up working curves to have many illusions left about the process. For the serious stuff I found out how to put confidences limits on the multiple parameters I was sucking out of the data, and if I tried to extract more parameters than the data would support,the confidence limits got remarkably large - as one parameter went up, another parameter could go down to keep the fitting curve more or less on the data.
Educational.
"Religious fervour"? Since you don't process rational arguments, they mightlook just like dogmatic assertions to you. Don't worry. God still loves you even if you can't make sense of his creation.
The 17-year "pause" in the warming looks rather like the other bobbles the Atlantic Multidecadal Oscillation imposes on the record.
Anthony Watt has very kindly given you 160 years of bobbly data to look at.
Admittedly, the bobbles included prolonged negative-going bits in the bits before 1900, while they now are now only "pauses" in a largely upward progression - so you've got to be a seriously a head-in-the-sand denialist like Anthony Watt to see them as some kind of negation of an underlying upward trend.
He'd get less support from the Heartland Foundation if his perceptions werea little better schooled. What's your excuse? Nobody is going to pay you for ventilating your ill-founded delusions, so you've got to be compensatingfor an insecure childhood or something equally unfortunate.
Raveninghorde
I spent too long curve-fitting data to set up working curves to have many illusions left about the process. For the serious stuff I found out how to put confidences limits on the multiple parameters I was sucking out of the data, and if I tried to extract more parameters than the data would support, the confidence limits got remarkably large - as one parameter went up, another parameter could go down to keep the fitting curve more or less on the data.
Educational.
"Religious fervour"? Since you don't process rational arguments, they might look just like dogmatic assertions to you. Don't worry. God still loves you even if you can't make sense of his creation.
He'd get less support from the Heartland Foundation if his perceptions were a little better schooled. What's your excuse? Nobody is going to pay you for ventilating your ill-founded delusions, so you've got to be compensating for an insecure childhood or something equally unfortunate.
So when Ben Santer said it needs 17 years to see global warming and
there hasn't been any for 17 years?
https://www.llnl.gov/news/newsreleases/2011/Nov/NR-11-11-03.html
/quote
The LLNL-led research shows that climate models can and do simulate
short, 10- to 12-year "hiatus periods" with minimal warming, even when
the models are run with historical increases in greenhouse gases and
sulfate aerosol particles. They find that tropospheric temperature
records must be at least 17 years long to discriminate between
internal climate noise and the signal of human-caused changes in the
chemical composition of the atmosphere.
/end quote
The RSS temperature record shows no warming for 16 years 8 months.
http://wattsupwiththat.com/2013/08/25/rss-flat-for-200-months-now-includes-july-data/
So far no sign of a "signal for human-caused changes".
Believing in CO2 warming when there is no warming is pretty weird.
Raveninghorde
did you notice his graph 13?
2005 and beyond are cooling according to him - but the global averages
were amongst the recorded highest. Great model he came up with - stuffed
and proved wrong before he even posted.
That was a political and not an engineering comment.
Because recent temperatures are high doesn't stop there being a
downward trend since 2005:
http://www.woodfortrees.org/plot/hadcrut3vgl/from:2005/plot/hadcrut3vgl/from:2005/trend
Clear downward trend on HADCRUT3 which is the dataset he analysed.
Bill Sloman
/quote
/end quote
"At least 17 years". Back in 2003, the significance of the Atlantic Multidecadal
Oscillation hadn't been fully grasped - that press release talks about the El Nino/La Nina oscillation, which is the same kind of thing, but cycles a lot more rapidly.
Don't worry. The greenhouse effect is still working, even if the ocean currents are injecting enough noise into the signal you choose to look at to make it hard to see in the short term.
Concentrating your attention on just the last 17 years is equally weird.
Not believing in the greenhouse effect is a good deal weirder. One of the intellectual triumphs of our age is that we have worked out why and how the earth started alternating between ice ages and interglacials 2.6 million years ago.
Milutin Milankovitch explained the timing of the alternation of ice ages and interglacials back in the 1920's, but the changes in the heat being absorbed by the earth then known about weren't big enough to explain the changesin the earth's temperature. The fact that the large ice sheets covering the large parts of the northern lands masses during an ice age reflected a lot more solar radiation than ice-free forest and tundra went quite a way to explaining the difference, but it wasn't until we had ice core data that showed the atmospheric CO2 levels dropped from about 280ppm during an inter-glacial to about 180ppm during an ice age that we could balance the thermal budget.
It turns out that as the climate - and the oceans - start to warm up at theend of an ice age, the carbon dioxide dissolved in the oceans starts coming out of solution. This doesn't happen overnight and in fact there's a roughly 800 year lag between the start of the warming and the rise in atmospheric carbon dioxide concentrations, but once it gets under way temperatures rise pretty steadily up to the inter-glacial norm.
The difference between ice ages and inter-glacials is definitely discernable, and carbon dioxide levels do seem to have had an influence. The story isstill being fleshed out -see Shakun, Jeremy D., et al. (2012). "Global Warming Preceded by Increasing Carbon Dioxide Concentrations During the Last Deglaciation." Nature 484: 49-54 [doi:10.1038/nature10915] - but claiming that CO2 isn't a greenhouse gas isn't a viable hypothesis.
Bill Sloman
The prejudice is a more complete grasp of physics than Anthony Watt can claim - or Raveninghorde either. I'm a bit surprised to see you characterisingthe dragging in of physical reality as "obfuscation". It may work that wayfor the ignorant who don't understand physics, but it clarifies matters considerably for those who do.
Embeddeded in the analysis is the assumption that the processes that you are looking at are cyclic, which means that any extrapolation has to be a reversion to the mean.
We know enough about greenhouse warming to know that the baseline is shifting, and the strictly sine-wave only analysis can't capture that. Harmonically related sine waves form a great set of mutually orthogonal fitting functions, but it doesn't follow that the process that you are looking at are well-described by sine waves.
Which rather neglects that the denialist counter-propaganda is entirely driven by money and commercial interest. People who make money out of extracting fossil carbon and selling for fuel have a strong interest in devaluing the scientific case for anthropogenic global warming - in exactly the same way that the tobacco companies had an interest in devaluing the scientific evidence that smoking was bad for your health. It's a trifle comic to find that some of the people who were active for the tobacco companies are now getting money from Exxon-Mobil.
http://en.wikipedia.org/wiki/Merchants_of_Doubt
Even
came from!
That's what Exxon-Mobil wants you to believe, and they seem to have spent enough money on sewing doubt to have have mislead people who ought to know better.
Bill Sloman
It used engineering data to make a political point.
But if you use a little more of the data set, it becomes an upward trend. If you go back to 1850, it becomes a totally unambiguous upward trend.
It's all nitpicking if you take the record back for a million years or so - as we now can - and can see the alternation between ices ages (CO2 levels of about 180ppm) and interglacials (CO2 levels around 280ppm).
The current scinetific understanding of what has been going on over the past 2.6 million years (which Raveninghorde has yet to get his head around) provides a useful perspective on today's temperature excursions.
Bill Sloman
Projecting future climate by regression analysis, over a short timebase, is
nonsense. Doing it by computer simulation, as most climatologists do, is just
more-compute-intensive nonsense.
John Larkin sees climatologists doing computer simulations in the same way that he uses LTSpice, running the simulation for just long enough to produce the behaviour he wants to see then stopping the simulation before the circuit can move off in a direction he doesn't fancy.
Climatologists run lots of different simulations, using a wide range of different models. Nobody thinks that any one model predicts physical reality, but by comparing lots of simulations they do get some kind of feel for what's going on and can deliver a rough idea of the way the climate is going toevolve.
Crude and imprecise as their predictions are, they are a lot more reliable than John Larkin's wishful thinking, and provide a persuasive case for us to trade off a bit of economic growth in favour of getting more of our energy from renewable sources.
Raveninghorde
So the science was settled but the alarmists hadn't grasped the
significance of the AMO.
Raveninghorde
I corrected a factual error by David. Don't see thatt as an attack on
your religion.
Bill Sloman
The El Nino/La Nina and AMO change global temperature by changing the way heat gets from the equator to the poles. It doesn't affect the amount of heat being absorbed and re-radiated by the planet, but it does have a short term effect on the temperatures measured at the surface of the planet. At thetime this tended to be described as "noise on the temperature record".
The fundamentals of the greenhouse warming have been widely accepted since the 1990's, so the science really is settled, but the short term fluctuations do require a more detailed understanding than we've got right now - but the Argo Buoy program is starting to deliver.
The program was proposed back in 1999, in part to fill in this gap in our knowledge, the 3000 buoy fleet was fully deployed in 2007, and the data collected is now being fed into climate models.
http://en.wikipedia.org/wiki/Argo_(oceanography)
Bill Sloman
I corrected a factual error by David. Don't see that as an attack on
your religion.
You didn't correct a factual error. You indulged your usual enthusiasm for picking the time interval over which to estimate the "trend" in order to beable to present the result you thought that David should have seen.
This is a fairly serious error in technique. The planet wasn't created in 2005, and if you want to work out what's going to happen to it over the nextcentury or so, you need to understand what been happening over the past few million years, rather than concentrating on the last eight or 17 years.
There's loads of evidence available on the subject - ice cores, layered lake and ocean sediments and so forth. Take a look at it sometime. It won't bea revelation - science lets you make up your own mind about the message - but even you might find it educational.
Raveninghorde
You didn't correct a factual error. You indulged your usual enthusiasm for picking the time interval over which to estimate the "trend" in order to be able to present the result you thought that David should have seen.
This is a fairly serious error in technique. The planet wasn't created in 2005, and if you want to work out what's going to happen to it over the next century or so, you need to understand what been happening over the past few million years, rather than concentrating on the last eight or 17 years.
There's loads of evidence available on the subject - ice cores, layered lake and ocean sediments and so forth. Take a look at it sometime. It won't be a revelation - science lets you make up your own mind about the message - but even you might find it educational.
Bill you need new glasses.
David said:
/quote
stuffed and proved wrong before he even posted.
/end quote
I pointed out thst David was factually wrong as HADCRUT3 temperatures
have been falling since 2005. Graph 13 was not invalidated.
Bill Sloman
No. You need a new brain.
David said:
/quote
/end quote
No. You ignored what he wrote - which was that the global averages were amongst the higher ever recorded (note the plural "averages") - and told us topay attention to your "fact", which was that the trend line through the period was decreasing.
Here's a discussion of what's may be going on.
http://tamino.wordpress.com/2013/09/02/el-nino-and-the-non-spherical-cow/
It's couched purely in terms of El Nino and La Nina, but I read that as a catch-phrase for all the ocean-current related effects, which do seem to be inter-linked. The Argo buoy data about what's going on in the depths of theocean doesn't yet seem to have made it into the public discussions.
tells us that it is getting into published papers, but it doesn't yet seem to have been distilled down into digestible chunks that can get stirred into popular-science web-sites.
Raveninghorde
No. You ignored what he wrote - which was that the global averages were amongst the higher ever recorded (note the plural "averages") - and told us to pay attention to your "fact", which was that the trend line through the period was decreasing.
Huh???
Just because temperatures are amongst the highest recorded does not
mean there is not a cooling trend since 2005 anymore than the fact
that a sine wave can be near it's highest voltage and the voltage is
reducing.
The point is David claimed: "Great model he came up with - stuffed and
proved wrong before he even posted." when the model is consistant with
the facts.
SNIP
Bill Sloman
Huh???
reducing.
Perfectly true and utterly irrelevant. You have to look at the data as a whole, and the whole data series is nois, which makes picky out a short term trend an exercise in cherry-picking idiocy.
the facts.
What model? Some whack-job delusion that the current "pause" in the warmingtrend reflects an underlying reversal, unlike all the previous pauses and reversals? That isn't a model, it's wishful thinking.
What started this off was you picking up Anthony Watt's bizarre analysis ofthe temperature record in terms of sinusoidal components, which imposes the preconception that the underlying temperature is static. If you look at the long-term historical record this is obvious nonsense, and if you look atthe longer-term geological record for the past 2.6 million years - which has been done - it looks even more nonsensical.
Martin Riddle
Climatologists run lots of different simulations, using a wide range of different models. Nobody thinks that any one model predicts physical reality, but by comparing lots of simulations they do get some kind of feel for what's going on and can deliver a rough idea of the way the climate is going to evolve.
Earth Climate models are more acurate than an LTspice Diode model?
Think not..
"The Earth system is just too complex to be represented in current
climate models. I don’t think they’ll get it right for a long time."
<http://www.foxnews.com/science/2013...global-warming-study-finds/?intcmp=latestnews>
Cheers
