Had my meter hooked up wrong, that’s what rushing will get ya.
Current draw is .001A without remote power in, voltage is 12V steady at suggested check points. Current .71A with remote power, voltage drops to 7V +/- at all suggested check points and ramps up to 11.5V every 20 seconds.
Let me try to summarize where I think I’m at.
Without power on the remote in terminal it appears all of the previous checks are good. It’s when power is put on the remote in terminal that when the voltage problems start, the power light stays lit. Just for the sake of argument let’s take the power supplys out of the picture as I don’t think it’s an issue. What component could be causing the voltage issues with power on the remote in terminal. My understanding is the remote in power is what turns this thing on. The 12V to the remote in is supplied by the radio when it’s turned on. When this unit gets the remote in power there is supposed to be a momentary delay and then it’s supposed to send 12V to the remote out to turn on other amplifiers.
Tried something different. One power supply on +12V and one on remote in. With just 12V on remote in I have 1.6V at pin 5. When I turn on the +12V ps the remote 12V is stable at the terminal but the +12V drops to 7V, turn off the remote power and the +12V comes back up.
Possible issue in this circuit?
Thanks,
Rick
