New guy here, first post. I should mention I know just enough about troubleshooting electronics to be dangerous but I can follow directions.
I did something really bad and am hoping maybe you guys can point me in the right direction. I have a JBL MS-8 digital signal processor/amp for my car. When I installed it I accidentally reversed the 12VDC power. I heard a pop and the first thing I checked was the 25A fuse which was blown. I replaced it and correctly wired the power. Now when I hit the reset button the power light comes on for about 15 seconds and then goes out. This unit also has a remote power circuit. This terminal receives 12vdc from the head unit to turn it on. It also passes the power back out to turn on 2 other amplifiers. This circuit works fine as the others amps are powered on.
With help from a friend at work I'm trying to see if I can get this thing functioning again. I do have a service manual. Below is a shot of the part of the circuit we are currently looking at. We pulled the diodes off the board to check them. Using a Fluke DMM set on the diode setting we get .618 and .468 and when we reverse the leads they both read 0. We inspected the board under a large lighted magnifier and can't see any visible damage. The only thing suspect is some dark material under the 2 caps (4700UF/35V) shown which I think may just be glue. The caps themselves are not bulging or discolored. Could they still be damaged? Any help with this will be greatly appreciated.
Thanks,
Rick
Thanks,
Rick
