markp
Hi All,
I'm intending to drive a piezo sounder using antiphase PWM outputs from a
micro (ATtiny88). The sounder is actually mounted on another PCB which is on
the underside of the lid of the box, with about 20cm of cable from the micro
on the motherboard. I'm concerned about what protection I need for the micro
My first thoughts were to use a pair of schottky diode clamps close to the
PWM outputs, which raises a question:
Can I assume these schottky diodes will start to conduct before the
substrate diodes, or should I put a small resistor between the micro and the
clamps?
Also since the sounder is essentially resonating, should I put a series
resistor in line with each drive to allow the voltage at the sounder to rise
above Vcc and below ground (and hence get louder sound output)?
Finally, do I need to worry about EMC, and would it be worth putting a
filter on each signal on the lid PCB (maybe a ferrite/capacitor or just a
capacitor)?
Thanks!
Mark.
clamps?
capacitor)?
Thanks!
Mark.
