Hi!
I`m pretty new to electronics (so please be gentle), but came across a problem with which I need some help.
I have an AC power source with variable output ranging from 150V to 5kV. I would like to branch this circuit to be able to use a LED with it (at will with a switch).
I`m pretty sure I will need a rectifier and probably a capacitor too, but how can I regulate the voltage for this additional circuit to supply only the required voltage for the LED. The whole thing should be pretty small (IC size).
Is it possible at all?
