My Dremel finally went bad after a sputtering. I can find a replacement switch/control cheap enough but I wanted to make sure it wasn't something else 1st. so I did some research. Hopefully this will help others. Btw the easiest way I found to bypass the board is to pull the control board out and short the 2 contacts. My values are for a 115V Dremel. The value I measured for a capacitor seems low from what I've read and there is a mystery part so if someone can enlighten me that would be good.
