Doubt about it 6-to-64 decoder
That line is connected to E2 .
It can be used as X6 if you need another address bit to create a 7 to128 decoder.
If unused, it should be connected to "1" constantly.
BTW,
you can used the 74154 to reduce the chip count.
You would use four 74hc154 and one 139, for a total of 5 instead of 9 ICs.
What is this decoder for there may be other implementations.
The #1 schematic is backwards from the traditional way of doing a staged address decoder. Usually the low order address bits to to all of the low level output generators, and the higher order address bits go to the pre-selector. #4 shows this.
ak
