ok so I have a microcontroller sending low voltage signal
That is connected to an N channel Mosfet (IRF9910PBFCT-ND)
That's what should drive power to the EMatch setting it off.
But I also wanted a Continuity LED (Green) so when the ematch is connected I get a green light.
Then when the unit is actively firing I wanted the Red LED to be on so I have another Mosfet P channel driven off the first to basically just reverse the power signal into a positive to drive the Red LED.
Then I'm not sure about the diode on the right, I think I needed something to prevent backflow when not activley firing the FETs.
Does this look right or am I way out in left field?
