sam
have a couple years old honda inverter (6.5 kW) generator and the fuel system has a
drain valve so last time when it was used to test out all connections in a total
blackout condition, ran sta-bil mixed with some premium fuel last month, drained the
fuel and closed valve
the sediment cup is clean and dry, all fuel lines are empty
changed oil and placed it into storage, non-airconditioned space
should the generator be occasionally run with some fresh fuel and if so, what type of
runtime (15 min, 30 min) ?
installed a new battery last month and charge it once a month (agm gel type)
total runtime on meter is 1 hour.
the generator is for emergency backup but as with everything, it surely deteriorates
after some amount of years but would like to keep it in best possible condition if
such is possible.
such is possible.
