I have a cheap Karaoke mic, which has a bizzare issue.
When i switch it off, the diaphram is still active, but not fully active.
Over a period of a few seconds, the input fades away, however, if i shout loudly in to it and turn up the volume on the amp, i can still hear input from the mic.
I opened it up, and I can't figure out how the switch works.
It appears to be a 3 pole on off switch.
From the XLR plug, i've 3 wires, Black, Red and Yellow.
The black wire (which I assume is ground) is soldered to the metal case of the switch.
Then both the red and yellow wires are soldered to two of the switch pins, which in turn run to the diaphram.
Its as if the switch is being bypassed, unless the ground is somehow involved.
Aplogies for the rubbish drawing
