Platforms
Content
hey wanna ask, if I use plastic varnish, the connection still can conduct electricity ?
Yes. You can still solder on on pcb connection. Hot solder lead will melt plastic varnish and solder flow on etch copper..
Just something to be shared
Give some comment about that for further improve.
Thank you
I mean those line of connection wont be insulated ?
If you mean the copper etch. Yes, it will be insulated by varnish coating. But you can still solder on it. You can still place your multimeter probe to test voltage , resistance or continuity of copper. Just add little pressure to the probe to puncture varnish coating.
You have to apply thin coat of varnish to newly etched pcb to avoid fingerprint mark that can cause corrosion.. Probably 1 or 2 swipe of clean fabric with varnish. Then you can drill holes and solder components.
How about you try to apply plastic varnish on that portion and apply solder then test for continuity. Then you will now what I'm explaining. To see is to believe.
