Sam Kaan said:
Well I am a hobbyist and very new to this. I decided to own a scope hoping
it will help me learn these stuffs better. I know some stuffs about
electronics but
don't have much experience witha scope. Sorry!
With the price of analog scopes almost cheaper than a good multimeter, I
think almost everyone can own a scope.
Your 16V transformer will most likely be isolated from the 120V mains in
your house, so you should be able to hook the ground (return) lead from your
probe to one side of the 16V output and hook the probe tip up to the other
side (polarity doesn't matter in this case...pick either lead of the OUTPUT
of the transformer for your ground (return) connection. Note that if you
were to try and measure the sine wave of the 120V(rms) output from the wall
outlet directly, you would need to exercise caution not to connect the
ground lead to either side of the wall plug. You could connect it to the
round hole in a 3 prong outlet if you want, but the scope is going to have a
return to ground through its power cord (assuming it is not some battery
operated thingy). Probably safer to use your little 16V transformer to
isolate you from the mains in any case. Note that you will see a sine wave
with a peak to peak voltage of about 46V or even a bit higher (since the
transformer is unloaded). If you looked directly at the wall voltage you
would see a sine wave that went from about -170V to +170V.
If you can buy or build a function generator, you could have some fun
exploring things like low pass and high pass filters, simple transistor
amplifiers, etc. with just a handfull of parts from even *gulp* Radio Shack.
I would recommend getting a good book on basic electronics, then maybe
getting Win Hill's excellent Art of Electronics. I guess you could start
with AoE, but you may want something a bit gentler.
Be safe, have fun, happy new year.
Rick
