W
W. Watson
I thought the right hand rule applied to determining the direction of B/H.
One simply wraps their right-hand around the (imaginary) wire wire with
their thumb aimed in the direction of the current. The fingers curl in the
proper direction. However, I was looking at a Navy manual on this subject,
and it shows as below. What am I missing. Does the Navy have a different
standard for current flow than physicists and EEs?
Magnetic lines of force are indicated by the letter H and are called H
lines. The direction of the magnetic lines may be determined by use of the
left-hand rule for a conductor: If you grasp the conductor in your left hand
with the thumb extended in the direction of the current flow, your fingers
will point in the direction of the magnetic lines of force.
Wayne T. Watson (Watson Adventures, Prop., Nevada City, CA)
(121.015 Deg. W, 39.262 Deg. N) GMT-8 hr std. time)
Obz Site: 39° 15' 7" N, 121° 2' 32" W, 2700 feet
