Dimming low power light bulbs
F
Frederick Williams
I know one can dim filament bulbs with triacs (or similar).
I think I know that one used not to be able to dim fluorescent lamps by
the same or similar means.
But can one dim low power lamps _of some kind_ by _some means_?
What is a low power lamp? Is it (at present) a fluorescent lamp?
Etc.
The questions are prompted by strip lights outside a brach of Sainsburys
that are on all day even in bright sunlight. I would have thought that
lamps could be installed the brightness of which could be controlled (in
an inverse fashion) by the brightness of the incident sunshine. But
would that require the strip lights to be replaced as well?
Please not that my knowledge of things electrical is limited.
Jamie
Etc.
When you say strip lights, it leads me to think you are talking about
LED strip lights? If that being the case, yes, they can be regulated but
not with a conventional voltage control unit. You need to get at the
string of LEDs and put a current limit device in there and maybe a photo
cell with some electronics to automate it abit.
Jamie
Daniel Pitts
A common, but by all means not the only, approach to "dimming" LED
lights is to use PWM. The wider the pulse width, the more fully "on"
they are. This can be quite efficiently done.
I don't know much about TRIACS, but from what I read on wikipedia, it
looks like using one to dim an LED strip would be reasonable.
O
operator jay
Etc.
Pretty much any commonly used lighting technology (incandescent, fluorescent
(T8, T12, T5, T5HO), compact fluorescent, metal halide, LED, high pressure
sodium, etc.) has means to do dimming. The costliness varies. Sometimes
special 'dimming ballasts' are needed wiht the fixtures, and very often,
special dimmers are needed. And yes, lighting can be controlled based on
daylight (search 'daylight harvesting'). While I do not know what
Sainsburys is (and I am assuming that 'brach' is just a typo for 'branch'),
in a scenario with outdoor fixtures mounted on a building exterior it would
be typical to do less intelligent controls. At least it would be typical in
much of north america. Either photocell control, or a timeclock, or a
combination of photocell and timeclock, might be used. The lights would
just be turned off and on in a more or less 'dusk til dawn' manner.
Astrological timeclocks are available that can accommodate changing
sunrise/sunset times with the seasons, and beyond that they can be
programmed with routines for weekdays, weeknds, holidays, and all sorts of
stuff. And they're not that expensive.
'Low power' may not be a well defined term, maybe 'efficient' is a better
term (depending on what you are actually asing, of course). Certain
technologies are more efficient than others, but if you want lots and lots
of light out of an efficient luminaire, you still need lots of power. All
of the lighting technologies mentioned above are OK for efficiency, except
for incandescent which is not good for efficiency. As rough numbers, I'd
say you can get 70 lumens per Watt to 140 lumens per Watt out of the
efficient technologies above. Fluorescent is probably around 100, and
widely used in normal indoor commercial applications. High pressure sodium
and metal halide are often used outdoors, with efficiencies between say 80
Lumens/W and 140. Incandescent is probably 10-20 lumens per watt. LED
lighting is changing fast. There is a ton of research money and effort
going into LED and it may well be the future of lighting. I don't think it
is king of efficiency yet for bulk lighting, generally speaking. Though for
some people it is the go-to technology. And the marketing hyping it is at
times perhaps a little ... zealous.
There are other newsgroups where you might get a better response on a
question like this. I'm a little rusty on them but
alt.enegineering.electrical might be one, sci.engr.lighting another. I'll
crosspost them in this reply.
j
F
Frederick Williams
LED strip lights?
No, fluorescent strip lamps. The things common in commercial
premisses. Sorry for not being clearer.
F
Frederick Williams
default said:
I take it you mean the eight foot long ones that are ubiquitous in
shopping centers and the like?
Yes, those.
They could be dimmed to maintain a minimum level, but the type of
dimmer it requires would be fairly sophisticated and the parts and
retro-fitting them would probably be too expensive
That is what I was wondering. Thank you.
F
Frederick Williams
Sainsburys is
A popular beat combo m'lud. Oh, no, sorry: a supermarket chain well
known in the UK.
Yes.
Thank you.
G
George Herold
When a true genius appears in the world, you may know him by
this sign, that the dunces are all in confederacy against him.
Jonathan Swift: Thoughts on Various Subjects, Moral and Diverting- Hide quoted text -
- Show quoted text -
Dimming fluorescent lamps is not all that easy.
The following is probably more than you want to know,
http://donklipstein.com/f-dim.html
The easist way to 'dim' a bunch of fluorescents may be to just turn
some off.
George H.
F
Frederick Williams
I think I heard that some years ago, hence my question and my wondering
whether more recent dimmer technology (or, perhaps, lamp technology)
allowed it or made it easier.
I'll read it. Thank you.
some off.
I may write a letter to the shop manager to that effect.
