CC
John said:I have all three - 547, 7104, several TDS2012s - in the lab, plus a
TDS3052 and a bunch of 11801-series samplers. The workhorse is the
TDS2012, and lately we just plop a rackmount 2012 in every test rack
we make.
The slower analog scopes are great for low-level stuff... a 1A7A or
7A22 plugin has switchable bandwidth and 10 uV/cm resolution, hard to
beat for analyzing hum and DAC noise.
One nice thing about the digital scopes is infinite persistance, great
for snooping digital data streams and noting worst-case timings in
realtime firmware. You can pull up/down test points at the start/end
of routines, like IRQs maybe, and run the sucker for a couple of hours
and see the extremes. I recently had a rare flakey temperature reading
from an LM71 and found the cause (occasional insufficient chip-select
setup time... it's a long story) with the TDS.
If I had to pick a single scope on a budget, it would be the TDS2012,
although the new Chinese "Agilent" might be good, too. Anybody use one
of those yet?
Yeah, I've got a MSO6054 at work. I now prefer it over the Tek TDS3054,
due mainly to the much deeper memory, and of course 16 digital channels.
I only wish Agilent would have made a 100MHz MSO model, so someday I
could afford to replace my TDS3014 at home.
Good day!
