Hi, and thanks for helping me ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I purchased Tusotek Auto DC-DC Constant Current Boost Buck Converter Voltage Regulator 6-35V to 1-35. I am trying to find digitally control the boost buck converter by replacing its 100K potentiometer with a 100K MCP41100 digital potentiometer. I tried using the digital potentiometer with Arduino and the DC-DC booster and it worked, but the booster does not go as high as with the original mechanical potentiometer. Would you know why I the digital potentiometer is no working as intended? What are the factors I must consider if I want to control boost buck converters with a digital potentiometer? Specs of the mechanical potentiometer can be found in the following website (scroll down): http://www.aliexpress.com/item/Trim...ohm-Variable-Resistors-100pcs/1596795967.html
