Chris
I didn`t get a wallwart yet, I do have a switching mode power supply I can use though. I have rebuilt the system again using the 7805, I still get the 20mV. Are you sure I shouldn't be concerned?? I can't actually put it to the test until I get the controller, which I am awaiting.
I have a question regarding the LED. This is going to sound simple to the electronics experts here I'm sure, but I just cant get my head around it.
You use the command Low 1 to switch the led on, how does this work. I have read the notes and looked at other examples and it seams that to switch on the flow of electrons you should use the command high 1, but in the case you are saying (I guess) switch off the channel with the command Low 1. Im not sure if you will be able to actually understand my question, sorry.
Justin
