If I get you right ... you are connecting a series resistor/regulator in each parallel
branch of the LED array.
Suppose you want to brighten a LED you'd decrease the resistance in that branch , but
that would increase the current flowing through it , which would then cause a decrease in
the currents flowing to the other LEDs ... so those would become dimmer . You'd then have
to work on the resistors in the other LED branches. Besides you'd have to take into
account the limiting current and the non linear voltage current characteristic of the LED.
You know what? You're about the stupidest sonofabitch I ever ran
across.
Here:
Ya take seven LEDs and hook them up in series with seven pots, like
this, and hook them all up in parallel with a _voltage_ source
(_not_ a current source) like this:
+V>----+--------+--------+--------+--------+--------+--------+
[POT]<-+ [POT]<-+ [POT]<-+ [POT]<-+ [POT]<-+ [POT]<-+ [POT]<-+
[LED] [LED] [LED] [LED] [LED] [LED] [LED]
GND>---+--------+--------+--------+--------+--------+--------+
You take the maximum current you can put into the lamps (1 amp each,
according to the OP) and you figure out what the values of the
rheostats need to be based on your highest supply voltage and the
_nominal_ voltage drop of the lamps according to the spec sheet.
Let's say that you have a 10V supply which can put out 10 amps, and
that the Vf of the lamps is 3V. Then, with the supply cranked to
the max, the value of the rheostats needs to be:
Vs - Vf 10V - 3V
R = --------- = ---------- = 7 ohms
If 1A
And they'll each need to dissipate:
P = If² R = 1A² * 7R = 7 watts.
Now, since we know that all of the LEDs aren't going to be equally
bright what we'll need to determine is how wide the range of
brightnesses will be and compensate for that by using the rheostats
to dim all the brighter ones down to the level of the dimmest one.
Let's say that the brightest one can be twice as bright as the
dimmest one with the same current (1 amp) going through them both,
and that the relationship between luminance and current is linear
because the OP said so. That means to dim the bright one down
you'll have to limit the current through it to 500mA, which means
the rheostat's high resistance has to be:
Vs - Vf 10V - 3V
R = --------- = ---------- = 14 ohms
If 0.5A
and it'll have to dissipate
P = If² R = 0.5A² * 14R = 3.5 watts
So, under those conditions it looks like what's needed is about a 15
ohm 15 watt adjustable power resistor. 15 watts because that's
resistor's _entire_ winding is rated for, and since we're
dissipating 7 watts across half the winding we have to up the rating
by a factor of two to keep the resistor happy. Actually, 25 watts
would be a better choice for the money.
Finally, once the array is trimmed up and all the LEDs are set to
the same brightness, the output of the power supply (remeber the
power supply?) can be lowered to dim the entire array and the
brightness of all the LEDs should track.
So _that's_ how ya do it.
