W
William Sommerwerck
You're letting your desire to be right overshadow your analysis.
How many battery powered drills does the average family need?
When every other garage sale has one, two or even three dead
drills, the statistics are hard to ignore.
The drills are rarely dead. It's almost always the batteries.
Take a design that was intended to be the cheapest initial
purchase cost based on the crappiest batteries available at the time.
Replace the cells with ones having 5x the capacity.
Now, even if the charger design was proper, fast charge termination
is unlikely to be anywhere near correct...as in "never terminates".
Sure, it often works. You feeling lucky?
"Well, do ya, punk?"
Not that many years ago I bought a Ryobi drill at Home Despot. It had a
conventional, non-rapid-charging charger. The battery died (in my view)
prematurely, and (violating Federal law) Ryobi could not supply a
replacement pack. So I bought a new drill (a Ryobi with a modular pack). Had
a replacement been available, I'd probably still be using the original.
Your correct observation about the average family rarely needing more than
one cordless drill only confirms my point.
You missed the point I was making -- rapid chargers almost always have some
form of auto cutoff. The kind of charging I was talking about (which I made
perfectly clear) was the "resistor-in-series-with-the-power-supply" type.
This is not a rapid-charge -- though it does charge faster than when the
cell voltage is lower. Such a system works fairly well -- eg, a Dust Buster.
I've gotten a good 200 recharges on my Model 5000, because I let the cells
run down before recharging, and I don't leave the unit on the charger all
the time.
NiMH "behavior" is "close-enough" to nicad that replacement
[often] works well.
I'm in complete agreement. The only thing we seem to differ on is the
consequences of when it DOESN'T work and if those consequences
are acceptable.
I completely agree with your complete agreement. The confusion occurred
because you misread me. I do not advocate rapid charging of any kind of cell
without a "fool-proof" shutoff system. I'm surprised at how far my MAHA
C9000 pushes NiMH cells. I keep an eye on it, and sometimes terminate the
charge cycle manually, because the cell has gotten warmer than I like, even
though the cell voltage is above 1.4 volts. I'm so cautious, I rarely charge
faster than 0.3C, though MAHA and other NiMH manufacturers recommend as high
as 0.5C.
