Difference between bridged and parallel amp?
Pooh Bear
François Yves Le Gal said:
I know. But you can parallel two amp modules, use proper current balancing
resistors and derive proper feedback (if needed).
That's true but the result is inferior to a single amp designed for the
purpose.
Graham
F
purpose.
Probably. But who cares nowadays with very high quality 1 Kw/4 Ohm class D
amp modules - with built-in SMPS, of course! - costing less than USD 200 in
OEM quantities ?
Phil Allison
"François Yves Le Gal"
in
OEM quantities ?
** Care to reveal the merchant ?
Tres interessant.
............ Phil
Pooh Bear
OEM quantities ?
I guess that depends on the THD figures and so on that you don't mind.
Graham
F
These modules are state of the art. A number of "audiophile" companies are
using them in stock form, other have slightly customized versions
manufactured for them.
John Fields
Then what about amps using multiple output devices in parallel ? They all
must look like near short-circuits to each other, don't them ?
F
The issue of price was raised:
http://www.audiokabel.dk/da-amps.htm
3900 Kroener exchanges out at about $650. About 6 DKK per
USD
That's the retail price for a *complete* amp, including case, connectors,
packaging et al.
The OEM module - here a 500 w/4 ohm version - costs much less, say less than
USD 150 FOB in OEM quantities.
Now a little bit of fun.
Let's have a look at the web site of a manufacturer using ASP modules:
Say, Red Dragon Audio.
http://www.reddragonaudio.com/main.htm
Their SA 1000 is sold direct for USD 1,799 (plus tax and shipping)
http://www.reddragonaudio.com/sa1000.htm
It uses two 1000ASP modules housed in a very nice aluminum box fitted with
sturdy sockets, jacks, binding posts and feet,, which looks identical to the
Entry 130 manufactured in China and sold in North America by Digital
Analogue DIY for USD 130 (Qty one, end user price).
http://www.digitalanaloguediy.com/entry130.html
Hmmm. Some modules - minimum order is half a pallet, 80 modules, so you have
to front something like 30 G's, some nice boxes, a couple of feet of
internal wiring, a mains cable, a sturdy UPS-proof box and a laser-printed
user manual
Presto, a new "manufacturer" is born...
(All this in order to show that the wide availability of OEM modules will
have the same effect on the audio market than it had on PC's: we'll see more
and more state of the art products at affordable prices. We'll also see
manufacturers trying to differentiate their offerings with tweaked or
custome solutions).
Arny Krueger
case, connectors, packaging et al.
Agreed.
less, say less than USD 150 FOB in OEM quantities.
Let's hope so, or the guys at
http://www.audiokabel.dk/da-amps.htm are running a
money-losing operation.
Now for a little bit of fun.
ASP modules:
shipping)
Pricey for a 600 wpc/8 ohm amp.
aluminum box fitted with sturdy sockets, jacks, binding
posts and feet,, which looks identical to the Entry 130
Digital Analogue DIY for USD 130 (Qty one, end user
price).
Isn't that the same gif on both web sites?
modules, so you have to front something like 30 G's, some
nice boxes, a couple of feet of internal wiring, a mains
cable, a sturdy UPS-proof box and a laser-printed user
manual
i.e., red dragon audio! ;-)
OEM modules will have the same effect on the audio market
than it had on PC's: we'll see more and more state of the
with tweaked or custom solutions).
Could be.
Stewart Pinkerton
The manufacturer... Scandinavian-based. Ice something.
Aah, are you referring to the B&O ICE modules? Proving very popular
now that they've proved their chops in the Lab 5 speakers.
F
It awfully looks like the same .gif.
I can't be affirmative as I've not run an ABX double blid triple Dutch
test...
Arny Krueger
triple Dutch test...
I think it was clever how they avoided the need for a new
gif by keeping the front panel clean. I do like at least a
power indicator on the front panel, though. ;-)
Rich Grise
No, they're the same, but they're jpg's. ;-)
$ ls en*
entry130_front.jpg-1 entry130_front.jpg-2
richgrise@thunderbird:~
$ diff entry130_front.jpg-1 entry130_front.jpg-2
Cheers!
Rich
PanHandler
One UK company sold/sells sound system amplifiers with two 60 W MOSFET amp
modules in parallel. It works, but it worried me a lot when I first saw
it. There are no current-sharing resistors and no cross-connections of any
sort. Not happy at full output at 20 kHz, though; smoke happens.
Amplifiers run on smoke. When the smoke comes out they stop running. Very
simple!
