Here is what Ratch is saying:
"Right now, with that high base resistance (100 k) in Q1, almost all the Icbo will go through the base-emitter junction of Q1, and get betatized into a much larger current. You should take out Rb, and put in an emitter resistor Re. The emitter resistor will look like (beta+1) Re from the base, and the Icbo will exit harmlessly through the base instead of entering the base-emitter circuit. Then you can adjust Ie=Ic by 2/((beta+1)*Re)"
He is turning the first transistor into an emitter follower. But the input voltage is just 2v.
How is he going to get his suggestion to work ?????????????
