Okay, so i'm all out of ideas. I live on a boat, which sadly leaks. Not very much, only about 50 litres per 24h. We collect this water in a 8 litre tank, which is the biggest one we can fit. We want this tank to empty itself. For this purpose we have installed an electric pump which runs from a relay. The relay is controlled by two switches, one in the top of the tank, and one at the bottom, When the top switch is closed, the relay activates and keeps itself opened until the bottom switch opens again. This runs on 12v. In theory. In practice, i make some hydrogen gas (i think) and consume about two amps.
The problem is that my "switches" are two copper wires that are supposed to be connected by the water when it rises, but this doesnt seem to work. When i put voltage on the wires, they consume ca 2 amps and create lots of bubbles. I can get ca 40 mA through the water and into the relay, but this is not enough to turn it on. Im considering amplifying the signal with transistors, but cant get hold of any here in cape verde. I also wouldnt know what kind of transistor Id need.
I have tried building switches that connect wires when a cork floats up in a tube, but they are unreliable, especially when the boat rocks.
Does anyone have an idea of how i can build a "no moving parts" switch or in another way solve this problem? Id be very grateful for any ideas!
