You can call it a secret
but actually its an instrument I am trying to work around . I need to know precise coordinates of the platform when the hinged rod is exactly horizontal. As of now we use an arbitrary method i.e when it appears the rod is horizontal we note down the position of the platform. I am trying to make something which could be more precise.
Coming to why I want to freeze the display? well so that I know when the rod was exactly horizontal, the readings from the IMU on the platform when the rod is is in any other position is not required.
I am uploading the code I am using on the IMU . Please let me know where and what I need to modify.
And this is the code for Tilt senson from Robojax
I need to change the LED .HIGH to something to freeze the display. Buzzer is optional.
Looking forward to your advice.
Code:
/* This is an example where we configure the data of the MPU9250
* and read the Acceleration data and print it to the serial monitor
* Arduino pin | MPU9250
* 5V | Vcc
* GND | GND
* A4 | SDA
* A5 | SCL
//Includes
#include <Wire.h>
#include "U8glib.h"
// Display
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NO_ACK); // Display which does not send AC
//Gyro Variables
float elapsedTime, time, timePrev; //Variables for time control
int gyro_error=0; //We use this variable to only calculate once the gyro data error
float Gyr_rawX, Gyr_rawY, Gyr_rawZ; //Here we store the raw data read
float Gyro_angle_x, Gyro_angle_y,Gyro_angle_z; //Here we store the angle value obtained with Gyro data
float Gyro_raw_error_x, Gyro_raw_error_y ,Gyro_raw_error_z; //Here we store the initial gyro data error
//Acc Variables
int acc_error=0; //We use this variable to only calculate once the Acc data error
float rad_to_deg = 180/3.141592654; //This value is for pasing from radians to degrees values
float Acc_rawX, Acc_rawY, Acc_rawZ; //Here we store the raw data read
float Acc_angle_x, Acc_angle_y,Acc_angle_z; //Here we store the angle value obtained with Acc data
float Acc_angle_error_x, Acc_angle_error_y,Acc_angle_error_z; //Here we store the initial Acc data error
float Total_angle_x, Total_angle_y,Total_angle_z;
void setup() {
Wire.begin(); //begin the wire comunication
Wire.beginTransmission(0x68); //begin, Send the slave adress (in this case 68)
Wire.write(0x6B); //make the reset (place a 0 into the 6B register)
Wire.write(0x00);
Wire.endTransmission(true); //end the transmission
//Gyro config
Wire.write(0x1B); //We want to write to the GYRO_CONFIG register (1B hex)
Wire.write(0x10); //Set the register bits as 00010000 (1000dps full scale)
Wire.endTransmission(true); //End the transmission with the gyro
//Acc config
Wire.beginTransmission(0x68); //Start communication with the address found during search.
Wire.write(0x1C); //We want to write to the ACCEL_CONFIG register
Wire.write(0x10); //Set the register bits as 00010000 (+/- 8g full scale range)
Serial.begin(9600); //Remember to set this same baud rate to the serial monitor
time = millis(); //Start counting time in milliseconds
/*Here we calculate the acc data error before we start the loop
* I make the mean of 200 values, that should be enough*/
if(acc_error==0)
for(int a=0; a<200; a++)
Wire.write(0x3B); //Ask for the 0x3B register- correspond to AcX
Wire.endTransmission(false);
Wire.requestFrom(0x68,6,true);
Acc_rawX=(Wire.read()<<8|Wire.read())/4096.0 ; //each value needs two registres
Acc_rawY=(Wire.read()<<8|Wire.read())/4096.0 ;
Acc_rawZ=(Wire.read()<<8|Wire.read())/4096.0 ;
/*---X---*/
Acc_angle_error_x = Acc_angle_error_x + ((atan((Acc_rawY)/sqrt(pow((Acc_rawX),2) + pow((Acc_rawZ),2)))*rad_to_deg));
/*---Y---*/
Acc_angle_error_y = Acc_angle_error_y + ((atan(-1*(Acc_rawX)/sqrt(pow((Acc_rawY),2) + pow((Acc_rawZ),2)))*rad_to_deg));
/*---Z---*/
Acc_angle_error_z = Acc_angle_error_z + ((atan((Acc_rawX)/sqrt(pow((Acc_rawY),2) + pow((Acc_rawY),2)))*rad_to_deg));
if(a==199)
Acc_angle_error_x = Acc_angle_error_x/200;
Acc_angle_error_y = Acc_angle_error_y/200;
Acc_angle_error_z = Acc_angle_error_z/200;
acc_error=1;
}//end of acc error calculation
/*Here we calculate the gyro data error before we start the loop
if(gyro_error==0)
for(int i=0; i<200; i++)
Wire.write(0x43); //First adress of the Gyro data
Wire.requestFrom(0x68,4,true); //We ask for just 4 registers
Gyr_rawX=Wire.read()<<8|Wire.read(); //Once again we shif and sum
Gyr_rawY=Wire.read()<<8|Wire.read();
/*---X---*/
Gyro_raw_error_x = Gyro_raw_error_x + (Gyr_rawX/32.8);
/*---Y---*/
Gyro_raw_error_y = Gyro_raw_error_y + (Gyr_rawY/32.8);
/*---Z---*/
Gyro_raw_error_z = Gyro_raw_error_z + (Gyr_rawZ/32.8);
if(i==199)
Gyro_raw_error_x = Gyro_raw_error_x/200;
Gyro_raw_error_y = Gyro_raw_error_y/200;
Gyro_raw_error_z = Gyro_raw_error_z/200;
gyro_error=1;
}//end of gyro error calculation
}//end of setup void
void loop() {
timePrev = time; // the previous time is stored before the actual time read
time = millis(); // actual time read
elapsedTime = (time - timePrev) / 1000; //divide by 1000 in order to obtain seconds
//////////////////////////////////////Gyro read/////////////////////////////////////
Gyr_rawZ=Wire.read()<<8|Wire.read();
/*Now in order to obtain the gyro data in degrees/seconds we have to divide first
the raw value by 32.8 because that's the value that the datasheet gives us for a 1000dps range*/
/*---X---*/
Gyr_rawX = (Gyr_rawX/32.8) - Gyro_raw_error_x;
/*---Y---*/
Gyr_rawY = (Gyr_rawY/32.8) - Gyro_raw_error_y;
/*---Z---*/
Gyr_rawZ = (Gyr_rawZ/32.8) - Gyro_raw_error_z;
/*Now we integrate the raw value in degrees per seconds in order to obtain the angle
* If you multiply degrees/seconds by seconds you obtain degrees */
/*---X---*/
Gyro_angle_x = Gyr_rawX*elapsedTime;
/*---X---*/
Gyro_angle_y = Gyr_rawY*elapsedTime;
/*---Z---*/
Gyro_angle_z = Gyr_rawZ*elapsedTime;
//////////////////////////////////////Acc read/////////////////////////////////////
Wire.endTransmission(false); //keep the transmission and next
Wire.requestFrom(0x68,6,true); //We ask for next 6 registers starting withj the 3B
/*We have asked for the 0x3B register. The IMU will send a brust of register.
* The amount of register to read is specify in the requestFrom function.
* In this case we request 6 registers. Each value of acceleration is made out of
* two 8bits registers, low values and high values. For that we request the 6 of them
* and just make then sum of each pair. For that we shift to the left the high values
* register (<<) and make an or (|) operation to add the low values.
If we read the datasheet, for a range of+-8g, we have to divide the raw values by 4096*/
/*Now in order to obtain the Acc angles we use euler formula with acceleration values
after that we substract the error value found before*/
/*---X---*/
Acc_angle_x = (atan((Acc_rawY)/sqrt(pow((Acc_rawX),2) + pow((Acc_rawZ),2)))*rad_to_deg) - Acc_angle_error_x;
/*---Y---*/
Acc_angle_y = (atan(-1*(Acc_rawX)/sqrt(pow((Acc_rawY),2) + pow((Acc_rawZ),2)))*rad_to_deg) - Acc_angle_error_y;
/*---Z---*/
Acc_angle_z = (atan(-1*(Acc_rawX)/sqrt(pow((Acc_rawZ),2) + pow((Acc_rawY),2)))*rad_to_deg) - Acc_angle_error_z;
//////////////////////////////////////Total angle and filter/////////////////////////////////////
/*---X axis angle---*/
Total_angle_x = 0.98 *(Total_angle_x + Gyro_angle_x) + 0.02*Acc_angle_x;
/*---Y axis angle---*/
Total_angle_y = 0.98 *(Total_angle_y + Gyro_angle_y) + 0.02*Acc_angle_y;
/*---Z axis angle---*/
Total_angle_z = 0.98 *(Total_angle_z + Gyro_angle_z) + 0.02*Acc_angle_z;
/*Uncoment the rest of the serial prines
* I only print the Y angle value for this test */
// text display tests
u8g.firstPage();
do {
u8g.setFont(u8g_font_unifont);
u8g.setPrintPos(5,10);
u8g.setFontLineSpacingFactor(uint8_t (51));
u8g.print("X: ");
u8g.print(Total_angle_x);
u8g.setPrintPos(5,30);
u8g.print("Y: ");
u8g.print(Total_angle_y);
u8g.setPrintPos(5,50);
u8g.print("Z: ");
u8g.print(Total_angle_z);
} while( u8g.nextPage() );
Serial.print(" :Xº");
Serial.print(Total_angle_x);
Serial.print(" | ");
Serial.print(" :Yº");
Serial.print(Total_angle_y);
Serial.print(" :Zº");
Serial.print(Total_angle_z);
Serial.println(" ");
delay(200);
Code:
// Tilt Sensor code for Robojax.com
#define TILT 2 // pin 2 for front-left sensor
#define LED 8 // pin 3 for front-right sensor
void setup() {
Serial.begin(9600);
Serial.println("Robojax Tilt Test");
pinMode(TILT, INPUT);//define Data input pin input pin
pinMode(LED,OUTPUT);// define LED pint pin as output
void loop() {
int TILT_SENSED = digitalRead(TILT);// read TILT sensor
// if tilt is sensed
if( TILT_SENSED ==LOW)
digitalWrite(LED,HIGH);// set the LED pin HIGH and buzzer will buzz
Serial.println("Tilt detected");
}else{
digitalWrite(LED,LOW); // Set the LED pin LOW to turn it OFF or buzzer OFF
Serial.println("Normal");
delay(200);
