Hi all,
My Samsung TV have flashing problem. I opened it up and found some bulging capacitors which I replaced.
Because the capacitors were bulging, I suspect a problem in the PSU.
Here's a picture of a normal PSU board (can search by BN44-00157A):
http://www.ebay.com/itm/PSU-POWER-S...560278?hash=item3ac106ef16:g:hyUAAOSw8RJXBYOf
After replacing the bad capacitors, the flashing problem still exists; so I looked for other issues.
Then I stumble upon an AC current in the heat sink (left most in that picture) !!! The current was 0.7-1.1 volts! Is this even normal? or does it mean the component attached to those heat sinks are broken/ leaking? I was testing that by attaching the red probe to the heat sink, and the black probe at the ground casing (TV was turned on obviously).
The heat sink with this problem is attached to a bridging rectifier, here's the spec of it :
Glass Passivated Bridge Rectifier, TS15P01G, Peak Reverse Voltage: 600 V, Vf - Forward Voltage: 1.1 V
http://www.mouser.com/ProductDetail/Taiwan-Semiconductor/TS15P05G/?qs=tHU/lV7kTySjz0UsGI/2gg==
My multimeter only has Volts/ Current/ Resistance test (no diode test) so I was not able to test the bridge rectifier properly. I did a resistance test on the +, -, and AC nodes and the resistance looked "OK". Does a current in the heat sink indicate a problem with the bridge rectifier?
Thanks in advance,
Gary
Thanks in advance,
Gary
