doing a little home project here for an opamp my cousin tells me I can make one with these components but I need to design the schematics, he tells me I can't do it but I think you can!
help me out!
Single ended supply
Power supply 9V dc at 10mA
Output impedance: 1kΩ
Input impedance: 2.2kΩ
Adjustable output level: max 40dB variable resistor, potentiometer
Frequency range: 20Hz to 20kHz +/-3dB
Max input signal 40mV
Max amplifier gain = 100
It is to use a 741 op-amp in the inverting mode on a single power supply built on Vero- board
Components given, parts list:
Resistors:
2.2kΩ
22kΩ ×2
220kΩ
RV1 1kΩ
Capacitors:
1µF ×2
10µF
IC
741 OP-AMP
help me out!
Single ended supply
Resistors:
2.2kΩ
22kΩ ×2
220kΩ
RV1 1kΩ
Capacitors:
1µF ×2
10µF
IC
741 OP-AMP
