Michael
Hi - I'm attempting to design a circuit using an Avalanche Photo Diode
(APD) to detect pulses sent out by a laser diode, as part of a Time Of
Flight (TOF) laser range finder. My goal is to get really sharp pulses
from the APD circuit (ideally with rise times under 100ps, even better
would be under 10ps). I don't need single photon counting ability -
but the greater the sensitivity the better.
I have never worked with an APD before, so I've been reading as much
as possible about them. My understanding is this: you reverse bias
them with a very large voltage that is beneath their breakdown
voltage, normally 100 or more volts. You put a shunt resistor in
series with the APD, and use that to measure the current flowing
through it. I'm assuming this would be done with a really high speed
op-amp. Typical current I believe is in the nano-ampere range. I think
this is all dark current? When light hits the APD, the current will
increase for a brief moment, with the magnitude of the added current
controlled by the magnitude of the bias voltage, the larger the bias
the larger the current increase. (with the exact relationship shown in
a graph in the APD's datasheet)
How am I doing so far?
I am hoping to use a visible laser diode (for safety, as well as ease
of debugging). Red seems like a good option as red diodes are so
common and inexpensive. But either way - visible means that I'll need
a silicon APD. I can't find many distributors for APDs, unfortunately.
I found digi-key has a couple: http://dkc3.digikey.com/PDF/T072/P2091.pdf.
Does that pricing seem normal? The cheapest they have is $126.92 in
single quantities. Are there other distributors or manufacturers I
should be looking at?
Also, I've seen some work done with actively cooling the APD to
decrease the dark current. When is this necessary? From where I've
seen it done, it looks to only be done when you're trying to count
single photons, which is not what I'm trying to do.
Lastly - what is the benefit of having a large active area? It seems
that price is directly proportional to active area. To me, it seems
like putting a big lens in front of a APD with a small active area
would serve the same purpose as using an APD with a large active area,
but I suspect that I'm missing something.
Can anybody shed some light on APDs for me?
Thanks so much!
-Michael
Thanks so much!
-Michael
