Hi!!,
I have a question regarding designing 3 sequential circuits using an op-amp, diode, and transistor. Question is described below.
The circuit is a comparator that supplies a 3-step sequence of output signals.
The circuit should behave in the following manner.
* Pressing S1 (Switch) discharges C1 and lights LED 1 (and LED 2 briefly).
* C1 then charges through R4.
* As charge on C1 passes 3 and 6 volts, LED 2 and 3 glows in sequence.
* Reduce R2 to balance time delay sequence and reduce delay time.
* Delays shown will vary with tolerance of C1.
Need to use the following IC components:
· LM1458
· 2N2222
· 1N914
The power supply of the circuit is 9V DC
LED 1 is Red LED
LED 2 is Green LED
LED 3 is Blue LED
You need to use and calculate the values of the following components for the circuit.
Ø Potentiometers, or Variable Resistors
Ø Resistors
Ø Capacitors
Help would be appreciated.
Thank you,
· LM1458
· 2N2222
· 1N914
LED 1 is Red LED
LED 2 is Green LED
LED 3 is Blue LED
Ø Resistors
Ø Capacitors
Thank you,
