Deleted Messages on Answering Machine
Senin
My housekeeper accidentally deleted all the messages (including my 2
year old daughter's) from my Uniden 900 MHz 378 series telephone
answering machine. Any possibible way of getting those messages back?
Tim
I had a GE digital answering machine at one time that did not delete the
messages until new ones came in. Even though you pressed the erase or
delete button, you could still play the old messages until a new one
came in and permanently deleted the old messages.
You have probably already tried pressing play again, but I thought I'd
throw it out there...
- Tim -
Pieter
Does it store it in a battery-backed up RAM? Or flash?
Then it probably is still there. Erasing a message is probably the
same as erasing a file on a disk, you just remove the entry in the
content table.
Do NOT record anything of you ever want those messages back.
You will need somebody who knows electronics (like me), can get the
flash, read it in an epromprogrammer and figure out the data. Probably
in a 8-bit format.
It is also possible that is uses an analog ISD or other soundchip.
They are difficult to crack as they can have internal datamanagement.
If it is possible depends on what is inside this machine.
Pieter
I also have a GE digital answering machine with deleted messages from my deceased father which I'd very much like to recover. I don't know anything about electronics but would it be possible for me to send you the machine and you could see if anything can be done.
Thanks for your time.
