im still new so please be nice
I am trying to build a circuit that will trigger a relay when the current is applied but only release it after the current has been cut for 30 seconds, but also turn it off if the input polarity has changed. It is for a car lighting system, and i want to integrate the lights with the central locking.
Basically it works like this
The car lock and unlock is going to be wired into the motor cable, which, reverses the polarity for lock/unlock. so once the doors unlock, i want the circuit to keep the lights on for around 30 seconds before turning off (Or even fading out). and also turn off if the engine starts within that period (a single 12v input will do) the lights are switched by on the negative run.
Im open to all ideas, so any help is greatly appreciated. Reply if you have any questions or need clarification on my not so technical detail I know what it is, but not always what it is called.
Cheers,
brendon
Cheers,
brendon
