Jan Panteltje
Well, I have this embedded system, and only 3.3V level out on serial.
Asked for a MAX233 in the shop.. needed to be ordered, was expensive...
Told them: Forget it, I will use transistors.
But the second thing, No supply should be used, not even the 3.3V
My solution? I control the terminal (Linux minicom) and the RS232 port too (outb() ).
So here it is folks:
Embedded connector
9 pol D connector --------0 >
c
TXD 3 -------------------------- 5k6 ------------------------ b NPN
| e
k |
Diode 1N1448 |
a |
GND 5 -------------------------------------------------------------------0 GND
+12V |
DTR 4 ---------------------- |
| 5k6 |
c | |
b ------| |
e NPN | |
RXD 2 ------------| | |
e | b
b ------| ----- c e----- 3k3 --------------0 <
c | |
| PNP c | NPN
| b------|
| e NPN |
| | 3k3
- 12V | | |
RTS 7 ------------------------------
All NPN transistors BC547, all PNP transistors BC 557.
As you can see the top is classical, but the reverse path uses a common base for level shifter
I start minicom, hardware flow control off, and then after that a small program that sets
DTR to +12 V and RTs to -12 V, there is my supply
Maxim defeated
Embedded connector
c
| e
k |
Diode 1N1448 |
a |
+12V |
| 5k6 |
c | |
b ------| |
e NPN | |
e | b
c | |
| PNP c | NPN
| b------|
| e NPN |
| | 3k3
- 12V | | |
Maxim defeated
